Parking Break Show Link
That almost looks like it's been riding on the axle, hub, or bolt heads The rear slot is also equally worn off.
What's the rear side (inner) of your axle flange and wheel bolt heads look like?
Man not sure, but if you're refering to a parking BRAKE I'd check to make sure everything is tight when bolted up with little play so it can't rub, or if there is something else bent around it. If it's a parking BREAK, well, you should go to the dealer since you can't even spell "brake"...
I'm rebuilding the entire drum "brakes". Was just wondering if this was a common problem with the shoe link. I'm going to cough up the $20 for new links and double check if anything rubs..hopefully not.
I think the image was taken at a funny angle, the mount looks a little bent, but it's all gravy.
