What radiator cap for 200ci motor?
Old 11-26-2011, 11:21 PM
Tilley
Tilley's Avatar
Default What radiator cap for 200ci motor?
I have a 1965 with a 200ci motor. The motor is completely rebuilt with "sleeves" returning back to it's original 200 ci status.
The other day ( day before Thanksgiving), I was leaving San Diego in about 70 degree weather when I hit HORRIBLE traffic. After a few minutes the car started to get hot and the car started to stumble and I had to give it a little gas to keep it idling. I think the stumbling was vapor lock.
I have a Autolite 1100 WITHOUT a spacer.
The cam on this motor is a larger one than stock.
The motor rebuilder's said I've increased my horsepower by about 40 horses.
I have a three row aluminum radiator.
4-blade fan and NO radiator shroud.
180 degree thermostat.
How do I keep my car cool and running at the right temperature?
QUESTION:
1. The radiator cap is 13 pounds...should I keep it or get a 9 or 11 pound cap?
2. Should I get a 160 degree thermostat, keep my 180, or get a 190 degree one?
3. Is a 5-blade fan with a shroud overkill?
HELP!!!
Tilley is offline
Old 11-26-2011, 11:37 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
you should use the stock lb cab and use the stock thermostat...you dont want 160....i would add a fan with a clutch and a shroud...but a shroud will help more than anything
rmodel65 is offline
Old 04-11-2012, 04:30 PM
jesus
jesus's Avatar
tengo un fairmont del 79 motor ford 200 con headers y flowmaster pero quiero reemplazar su balancin original por el balancin regulable de Clifford performance y el separador del manifold de escape para los cilindros tres y cuatro donde los puedo adquirir por internet ya que vivo en Venezuela
jesus is offline
Old 04-12-2012, 09:20 AM
abrush
abrush's Avatar
Hmm, if you are using the correct thermostat you shouldn't be having problems. I have a 65 mustang with the 200 inline 6 engine and it runs extremely cool even in 100 degree weather. I don't have a fan shroud on mine, have the stock four blade fan and am using the stock radiator. I also have the autolite 1100 carb and don't run a spacer. I will have to double check what the radiator cap is but I know I had ordered a new one about a year ago through CJ Pony Parts.
abrush is offline
Old 04-12-2012, 10:14 AM
Steve@CJPP
Former Sponsor
Steve@CJPP's Avatar
You can go with any of these.
http://www.cjponyparts.com/product.aspx?p=RC1
http://www.cjponyparts.com/product.aspx?p=RC2
http://www.cjponyparts.com/product.aspx?p=RC5
http://www.cjponyparts.com/product.aspx?p=RC6
Steve@CJPP is offline
Old 04-13-2012, 05:07 PM
ThetaTau87
ThetaTau87's Avatar
The higher the pressure cap the higher the temp before you system will boil over, but you need to keep your car from getting that hot to begin with. Adding a fan with more blades and a shroud will help quite a bit. Getting a fan with a clutch will reduce the drag of the fan when you're at higher speeds and cooling is being done by forcing air through the radiator with speed.
ThetaTau87 is offline
firehorse02
11-16-2015 11:28 AM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
logan409
09-26-2015 07:43 PM
Quick Reply: What radiator cap for 200ci motor?
