Serpentine belt conversions
Has anyone here done this? I couldn't find any real threads on it.
March Preformance makes some really nice looking ones. I think they are overpriced though. I would like some input on them, if anyone has used these? Links to pictures would be nice too!
RE: Serpentine belt conversions
If you want to use a serpentine belt, then you need to get a conversion radiator with the water inlet on the driver's side. NPD has these. You can use the EFI with the computer if you wish. Harnesses are available from Windsor-Fox. This installation is normally done with an aftermarket power steering pump if you have power steering. If not, I'm not sure about how to substitute the power steering pump. In the worst case, you can leave it in but cap it off so it does nothing but act as an idler for the serpentine belt. Ford Racing makes an adapter to eliminate the air conditioning compressor if you don't have or want air. Serpentine belt installations are fairly common but I don't have one, so I am only telling you about this conversion from memory.
bradleyb
11-27-2015 07:50 PM
autoedit
09-27-2015 06:37 PM
