which subframe connectors are the best
Old 12-16-2011, 02:36 PM
eatmyjeep
eatmyjeep's Avatar
i was doing some resuch on rear end suspensions. from what i understand from several sights, is that http://www.maierracing.com/ is very well respected among the race guys. I was going though there inventory and read something about 'there'' round stock subframe connectors being the way to go. any way check um out.
eatmyjeep is offline
Old 12-16-2011, 05:41 PM
67 evil eleanor
67 evil eleanor's Avatar
Subframe connectors are good, but if it was me, I would weld in a steel trunk/seat divider as well. It can be made from scrap. In a "real" test, it showed quiet a bit more improvment than subframe connectors.
67 evil eleanor is offline
Old 12-16-2011, 09:46 PM
andrewmp6
andrewmp6's Avatar
You make a good point i have seen some mustangs with stress cracks around the back glass before.
andrewmp6 is offline
Old 12-24-2011, 04:03 PM
Deviousfred
Deviousfred's Avatar
I'm very happy with the fitment on my Heidts connectors and the x-brace they offer for them. The brace also includes a driveshaft loop and this whole system ties into the leaf spring eye bolts and has provisions for under rider traction bars.
There is also a guy that makes tubular connectors locally and I can tell you first hand the quality of his work is some of the best I have ever seen.
http://www.ebay.com/itm/65-70-Mustan...0#ht_562wt_313
Fred
Deviousfred is offline
Old 12-26-2011, 01:59 PM
67 evil eleanor
How much does that weigh?
Old 12-26-2011, 03:36 PM
oxfordbp
oxfordbp's Avatar
Do they make a kit for this or would I use scrap sheet? What about an x brace instead of a divider?
oxfordbp is offline
Old 12-26-2011, 06:34 PM
Deviousfred
I could not give you an accurate weight on the whole set-up but from what I remember when I installed it, not a whole lot.
Old 12-26-2011, 06:37 PM
Deviousfred
I'm doing both. Mustangs Unlimited makes the divider pretty cheap.
http://www.mustangsunlimited.com/ite...asp?T1=A169+01
jwog666
12-27-2021 08:09 PM
guitarman376
10-11-2015 01:47 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
09-16-2015 07:53 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: which subframe connectors are the best
