73 suspension conversion to 95 mustang parts
Old 01-02-2012, 10:46 PM
Jasonwayne222
Jasonwayne222's Avatar
Default 73 suspension conversion to 95 mustang parts
Im looking at buyin a wrecked 95 to use all front suspension and brakes but does anyone know what it would take to make it work I guess I'll have to modify a lot
Jasonwayne222 is offline
Old 01-02-2012, 10:52 PM
andrewmp6
andrewmp6's Avatar
I wouldn't do it the 95 is strut on spindle where the 73 has a upper a arm the 73 will handle better.The only racing that uses a strut on spindle is drag racing everything else uses the old double a arms.
andrewmp6 is offline
Old 01-02-2012, 11:00 PM
jojobanks
jojobanks's Avatar
This.
Your current suspension setup is actually better than the newer style. For the amount of money you would spend retrofitting the 95 style front suspension on to your car, you could just throw some aftermarket parts at it and end up a lot better off.
jojobanks is offline
Old 01-02-2012, 11:17 PM
Jasonwayne222
Ok I'm also lookin at a complete suspension replacement from mustang depot it's all stock stuff but new control arms springs shocks leaf springs strafing rebuild kit and interior kit for 1400 do you know if this is a good kit I'm runnin 330hp not lookin for a super car just safe and reliable also some suggestions on disc brake conversions would be appreciated
Old 01-02-2012, 11:27 PM
jojobanks
jojobanks's Avatar
sounds like a pretty decent deal. I've ordered a few things from mustang depot and I haven't been let down.
I'm guessing you don't have power brakes? I know you can swap the front disc brakes off a granada if you can find one. Otherwise I don't have much for you here. I'm still rockin the manual drums on all 4 wheels.
Old 01-02-2012, 11:49 PM
Jasonwayne222
No I got power brakes but I want to upgrade to discs all around
Old 01-03-2012, 12:22 AM
jojobanks
jojobanks's Avatar
if you already have power brakes then I would plan to spend around $700 to convert to 4 wheel disc brakes.
Old 01-03-2012, 03:35 AM
andrewmp6
andrewmp6's Avatar
If you want factory style disc talk to http://www.chockostangclassicmustang.com/home.html but if you are going to run a 17 inch rim there is brackets to use the 98-04 cobra brakes.
Urambo Tauro
12-17-2016 03:30 PM
AMWill
AmericanMuscle.com
26
09-08-2015 01:32 PM
robjh22
08-17-2015 07:35 AM
daytooday
08-11-2015 09:22 AM
elraun
3.7L V6 Technical Discussions
08-09-2015 04:32 PM
Quick Reply: 73 suspension conversion to 95 mustang parts
