1969 Rectangle Clock
01-19-2012, 06:36 PM
How do i remove the **** from the time set post so that I can remove the lens?
01-23-2012, 02:44 PM
Anyone know how to remove the time adjust stem so that I can remove the lens? I imagine its the same for all clocks, round or rectangle.
Does it just twist off?
01-23-2012, 06:12 PM
On the round clocks I'm pretty sure the **** and the little "timer pointer" come off with the face, when you push in it engages the gears inside the clock to change the time.
I have no idea on square.
01-24-2012, 11:11 AM
Hmmm....
Are you saying on the round face, you push the **** in to engage the gears to change the time?
Mine is just the opposite in that you pull the **** and hold to change the time...
01-24-2012, 05:25 PM
Maybe you are right, its been a few months since I took it apart.
This may not help much but there is a link to the kit I used to convert mine to digital.
http://www.dakotadigital.com/PDF/CLK-69M.PDF
It steps through disassemble of the round clock, I didn't see a specific replacement for a square clock for a '69.
01-25-2012, 09:19 AM
looks like it does unscrew. Thanks for the link to the instructions.
aznpersuasion
07-11-2018 06:40 PM
LiquidDrink
09-29-2015 10:06 AM
MonsterBilly
09-20-2015 06:56 AM
BOBCATJACK
09-14-2015 02:18 AM
S'PortMustang69
08-30-2015 08:27 PM
1969 ,
69 ,
cars ,
classic ,
clock ,
clocks ,
dakota ,
dash ,
digital ,
foed ,
ford ,
forums ,
knob ,
mustang ,
rectangular ,
removing
