Fitting doors for full quarter replacement
Old 03-02-2012, 08:28 PM
jgemperline
jgemperline's Avatar
So I think I know the welds your talking about. It seems this would not help the back lower corner. Can you give me just a little more confidence that this will adjust my problem? Thanks!
jgemperline is offline
Old 03-03-2012, 05:36 AM
MustangsToFear
MustangsToFear's Avatar
All I can tell you is drill the spot welds out and twist the door, then put a smaller pair of vise grips on the tabs to see what you have.
MustangsToFear is offline
Old 03-03-2012, 10:15 AM
jgemperline
Ok. I just wanted to understand how pulling the outer skin on top front adjust the bottom rear. As i type it seams to make more sence. I'll give it a go. Thanks.
Old 03-04-2012, 05:46 AM
MustangsToFear
The aftermarket doors only have 6 spot weld on them. So it is very easy to twist the door once the tab is drilled out, trust me we do this all the time.
Old 03-13-2012, 08:41 PM
jgemperline
Just finishing the thread. It worked great. I can't believe it was that easy. Thanks so much.
Old 03-13-2012, 08:59 PM
OkBrent
OkBrent's Avatar
Im still a little lost on where exactly these spot welds are.... Can you discribe them a little better and show us your repair. Pictures are great for slow people likr me!!! Thanks for the help, I am also battling the twisted door fate. Brent
OkBrent is offline
Old 03-13-2012, 10:49 PM
jgemperline
Still Need to do a final OK then weld. But dang good for ten mins of drilling 4 welds and prying it open a bit.
Old 03-13-2012, 10:51 PM
jgemperline
Before:
Old 03-14-2012, 06:54 PM
MustangsToFear
You will also notice that the rear of the door isn't curved in like a Ford door. That is a easy fix also, just take your hammer and dolly to get the desired curve.
Old 03-14-2012, 07:10 PM
OkBrent
OkBrent's Avatar
WOW... I was way off, A picture is worth a thousand words. Thanks for helping the kid on the short bus!!! Brent
OkBrent is offline
Quick Reply: Fitting doors for full quarter replacement
