wanna make 500rwhp with my 1968 429
#21
The heads that he has (police interceptor) are actually very good heads.They are very similar to the CJ heads with bigger valves and ports than stock 429/460 heads...On a decent 460 shortblock (9.5-10:1 compression) with the right camshaft and intake/carb it should easily make around 500hp....
I have an old car craft article from 1984 where they used the 1968-70 style Dove heads with slightly bigger valves and mild porting on the exhaust, on a 10.4:1 compression 460..With a comp cams 292 hydraulic camshaft(244dur@.050 .544L) and offy port o sonic intake it made 507 hp and 530ft/lbs of torque..It did require an 850dp carb to get there though..Initial dyno tests with a 750cfm carb cost 50 hp!
#23
yes you can
I am using a Lunati cam with a 276 - 284 duration that works good with our high comp heads ( 10.1 - 10.5). A 850 cfm carb is also a good match for your desired HP. Make sure you have the rite lifters and valve springs for the cam. A C-6 may rob some hp from your engine but its strong and reliable.
#24
I have a 428pi in the machine shop right and the target for me was around 500 hp. I didn't want to go over 500 because, well, it's going in my 46 year old car. For my build, the main parts limiting parts was my heads. I went the Cobra Jet size Edlebrock Performer RPM heads for a 428. I matched it with the performer RPM cam as well. I will top it with the Air Gap intake and an 850 Quick Fuel or Holley carb. I guess that I wasn't really shooting for a horsepower number, really I just want a bad *** power block that has drivability. I know that I could have went with a more radical cam profile and maybe some better heads than RPMs and possibly a harder crank or even a stroker crank.
My heads I bought for $1800. I bought them in October of 2012 and I just got them last week. The manufacture date was Dec 2012, I guess they don't take orders for too many 428s. Anyways....you could probably have a better chance at building a 500hp 351 for $3k than building a rareish 429 500hp for $3k, although it would be easier to get 500hp out of a 429. Like previously stated on this thread, new heads and cam should do the trick for you. My budget for my motor is around $12k and I'm a working man just like you, I've been just saving my pennies and eating noodles for supper.
Keep us updated, I want to see what you do with this.
James
James
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
