Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs (Tech)
Sign in using an external account
Register Forgot Password?
Welcome to Mustang Forums!
Welcome to Mustang Forums.
P
Old 02-21-2012, 04:57 PM   #11
67t5ponycoupe
Vehicle: 1967 GT Coupe
How ever slight the chance do you really want to blow up the same engine twice? I would do a complete tear down, wash the block, new bearings with a complete inspection. Cylinder walls should be good and the heads should be good.
67t5ponycoupe is offline   Reply With Quote
Old 02-21-2012, 07:06 PM   #12
chucks_truck
chucks_truck's Avatar
Vehicle: 1966 Ford Mustang Coupe
Quote:
Originally Posted by Iskwezm View Post
when my hyd. cam went flat, i "washed" the engine with about 2-3 gallons of diesel and drained as per the recommendation of my engine builder. I then went to a roller cam and since then have had low oil pressure.Being that i had so many issues with Ford Performance, i gave up and let the engine be as it was.
Me personally, i would pull some rod caps and a main and check the bearing to make sure.No sence in wiping out a crank journal.Also cut your filter open and see if theres any metal and how fine it is. By the looks of it, is gonna be very fine, not chunks.
Yes it is a very fine particulate. I will let you know what I see in the filter though when I cut it open.
Quote:
Originally Posted by eZ View Post
I would put money on it that the bearings are all scorched and sometimes even a cylinder wall could get scratched bad enough to need to be bored.
What cam were you running?
I have an xe282hr that I need to sell.
I'm running a Comp Magnum 281HR. I just got myself another one.....
Quote:
Originally Posted by JMD View Post
I don't necessarily agree with that..... In practice, the small shards of metal will....
a. Mostly wash into the oil pan
b. Some will be too big to pass through the screen in the pick-up.
c. ALL will be too big to pass a properly functioning filter
IMO the biggest risks are
a. Some shards will find their way onto the surface of the new cam
b. The oil pick-up will become blocked
c. Tho oil pump will experience unusual wear from shards passing through
There are "risks" in not tearing the engine down for a rebuild/clean out, but IMO, if a little common sense is used in the repair, the risks are slight, slight, slight. These slight risks can be almost entirely mitigated by cleaning out the valley, and dropping the oil pan to inspect/clean the pan, pump, and pickup. (But, I would probably just flush the pan on the engine, engine in car, myself. )
By the time any car engine reaches 100K, it will have ingested lots of metal
I already have the pan off and there are no big chunks or anything, just fine particles suspended in the oil. After cleaning that, I'll probably do 2-3 oil flushes after I put it back together as well as checking the filter each time.
I'm willing to take the slight risk.
chucks_truck is offline   Reply With Quote
Old 02-22-2012, 10:41 AM   #13
OCHOHILL
OCHOHILL's Avatar
Vehicle: 66 coupe
Bummer.
Out of curiosity, have you looked at the valve springs? Did the offending lifter have a corresponding broken spring? Were the valve springs matched to the cam?
Do you recall downshifting a little too soon at any given time leading to an over rev condition? May be an over rev at upshift?
If it was mine, I would pull the motor and take a look at the bearings. I would probably replace the main and rod bearings assuming no sign of significant damage. You don't want lose a rod bearing at the track. There is a lot more at stake than just the cost of the motor. Your next snafu could be priceless.
Keep us posted on this. I haven't seen this often and would like to know the cause. thank you
__________________
The search function is a tool. Use it. It will save you time and money.
OCHOHILL is offline   Reply With Quote
Old 02-22-2012, 12:08 PM   #14
chucks_truck
Quote:
Originally Posted by OCHOHILL View Post
Bummer.
Out of curiosity, have you looked at the valve springs? Did the offending lifter have a corresponding broken spring? Where the valve springs matched to the cam?
Yes I did check out the valve springs. That was one of the first things I checked before taking the manifold off. But the springs are good, but I have no idea if they were right for the cam. So that's why I'm getting some new ones along with the cam.
And as for over revving, that is probably my problem I'm pretty sure I kept it under 5.5k, but I'm not 100 percent on that.
Old 02-23-2012, 02:49 PM   #15
OCHOHILL
OCHOHILL's Avatar
Vehicle: 66 coupe
Measure the spring height at valve open and close. Mark the offending springs. Take the offending springs and another set to a machine shop and have the tension checked at valve close and open. See if this matches the cam requirements. I think it is worth your time to determine why this happened.
__________________
Old 02-23-2012, 08:45 PM   #16
quicktime
Vehicle: 1991 ford mustang
this is a roller block,correct? or an older block with retro-fit setup?
quicktime is offline   Reply With Quote
Old 02-23-2012, 11:04 PM   #17
JMD
JMD's Avatar
Vehicle: 39 Ford
I am not going to claim to be an authority, but I can say that in my experience from owning a fair sized fleet of trucks, that I have never had to rebuild an engine because of a part getting ground up and contaminating the oil, ever. Many of them that have a $20,000 price tag for an engine rebuild, so if an engine munched a bull gear, or wiped a cam, I would often/usually just fix the damn thing for 1/4 the cost of a rebuild and move on.
I never saw suspended metal make it past the filter to destroy any bearings, nor did I ever see a cylinder bore chewed up.
Some of these engines are still in service, no rebuild, and over a million miles, and more than a half a million since some of these episodes.
Rebuilding a motor that does not need it is not only a waste of money, it is a crying shame.
Maybe I might pull a cap if I suspected oil starvation from a blocked pickup screen, or a damaged/failed pump, but this and a visual would be it for me.
How about all that metal that wears off freshly honed cross hatch marks in cylinders?
__________________
Building cars is EASY, building cars right is a mite bit harder.
JMD is offline   Reply With Quote
Old 02-29-2012, 01:10 AM   #18
norcalcougar
Vehicle: 1967,mercury,cougar
IMO you exceeded the rpm limits of your valve train, floated a lifter, which knocked the "dog bone" off....
Those rollers are heavier than standard lifters, which means that for a given valve train, the rpm capability is less for a roller than for a flat lifter.
It is MY OPINION that your failure is a result of valve train over speed, and probably nothing more.
Linked lifters would have prevented the lifter from turning in the bore, but stronger valve springs would have stopped the lifter from turning too, and should be used whether you go with linked lifters or the "spider and bones".
Build your engine with a rpm limit in mind, and a rev limiter will be a wise decision, especially if you are going racing.
norcalcougar is offline   Reply With Quote
MustangForums
Ford Mustang
Paid Advertisement
P
1965, 50, clean, diesel, f250, failed, lifter, lifters, metal, metallic, noise, oil, put, ratchet, train, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails Backup
