71 Coupe gas gauge not working - MustangForums.com
Old 02-27-2012, 09:57 PM   #1
Liam
Default 71 Coupe gas gauge not working
I recently got a 1971 Mustang Coupe and the gas gauge does not work. Regardless of the amount of gas in the tank it sits on empty. This is my first 71 so I'm not knowledgeable about the car. If anyone has dealt with this maybe a few pointers. Figured I'd ask before I started digging in. Thanks guys
Liam is offline   Reply With Quote
Old 02-27-2012, 10:07 PM   #2
rmodel65
Yukon Cornelius
rmodel65's Avatar
its probably the float that is on the arm of the sending unit...new gas is corrosive and will eat though them....the float is about 6$ from any mustang parts house
rmodel65 is offline   Reply With Quote
Old 02-27-2012, 10:13 PM   #3
oxfordbp
Not to thread jack, cause this might apply to OP as well
Does the tank need to be empy to remove the sending unit to replace the float?
oxfordbp is offline   Reply With Quote
Old 02-28-2012, 03:09 PM   #4
jlg2002
jlg2002's Avatar
oxford, yes the tank needs to be fairly empty to take the sending unit out (unless you really like the aspects of wearing that nasty gas smell for the next few days ) because it mounts on the front face of the tank.
Liam,
you need to check your fuel gauge circuits before you arbitrarily assume it's a sending unit (the problem could be the gauge, wiring or inst. Pnl connections, etc...)
with the key off and the rear of the car jacked up so you can access the rear axle area from underneath, locate the fuel tank sending unit wiring and pull it off of the tank unit, turn the ign key On and the gauge should go past full. turn the key off and attach a jumper wire from the loose fuel tank wire to a good ground (usually one of the tank mount bolts or exhaust hanger) turn the key on and the gauge should be below E. This check proves out the gauge wiring, inst pnl connection and power circuits. If the gauge doesn't go full scale when the wire is off, you most likely have a bad gauge or power issue
jlg2002 is offline   Reply With Quote
Old 02-28-2012, 10:03 PM   #5
Liam
Alright, I figured it was the float but I did notice today that when I put a few gallons of gas in the car and got in, it read about half full which is where it should have been, then as I drove it dropped back to empty and stayed there. I will definitely do as you recommended and check the circuits first. I knew that can happen but I had no idea how to check for it. Thank you very much, I will hopefully get to it in the next few days and let you guys know.
Old 02-28-2012, 10:31 PM   #6
rmodel65
Yukon Cornelius
rmodel65's Avatar
well the float might have emptied the gas inside when the tank was low then when you put some gas in it floated for a while then sank....but you can definitely check the circuit but every classic stang ive had has needed a float and not anything else
Old 02-29-2012, 10:45 PM   #7
Liam
Like I said, I may as well check the the circuit to be sure. The only way I know how to remove the sending unit and float is to remove the entire tank. Maybe it's a dumb question but is it possible to replace the float without removing the tank from the car? Thanks again.
Old 02-29-2012, 10:55 PM   #8
oxfordbp
Quote:
http://www.mustangmonthly.com/howto/...t/viewall.html
"Death Trap" my new 84 GT build thread 67LimeCoupe 5.0L General Discussion 45 11-25-2015 08:55 PM
New guy here from SE Michigan movielover40 New Member Area 5 08-27-2015 10:13 PM
How to Test Fuel & Alternator Gauges unit91 Classic Mustangs (Tech) 1 08-21-2015 11:44 PM
Alternator problem? jjwinel78 V6 (1994-2004) Mustangs 1 08-17-2015 03:34 PM
New from Pittsburgh chain New Member Area 6 08-17-2015 08:52 AM
1971, 71, 71 coupe, deep, fuel, gage, gas, gauge, guage, install, internet, mustang, powered, search, sensor, vbulletin
