toploader 4 speed help
i have a toploader 4 speed that was origionally paired with a 302, was wondering if anyone could tell me if it can be used with the 427 FE or if there is anyway to use it with the 427. any and all info would be great as this is my first restomod and i dont know much about transmission nd such.
thanks in advanced, Topher.
The pilot bearing section of the input shaft is longer on a small block toploader than on a big block one because the big block bell housing is not as deep as the small block one.
The parts are available from many sources, I've found Mark (the owner) at TOPLOADER HEAVEN to be as helpful and reachable as can be. He can sell you a shorter shaft and a CD that shows the step by step process for installing it. If you're in there you might as well rebuild the whole thing as replacing the shaft requires total dis-assembly of the tranny. It may sound difficult but it really isn't.
BeatnikFink
10-01-2015 08:00 PM
mungodrums
09-29-2015 09:18 PM
musnicki
09-23-2015 07:11 AM
