bell housing wont bolt to block flush
Old 02-29-2012, 08:02 AM
torinostroker
torinostroker's Avatar
Default bell housing wont bolt to block flush
mustang
sorry guys i know i am a torino guy, but my forum is currently down so going to outside help.
i have a 91, 331 and a 71 c4 i am combining. it was a 5 speed before now going to an automatic. when i bolt down the bell housing it always leave a small gap on one either left or right side. don't know what to do. the converter seated right, and lined up with flex plate fine.
also it was a manual before as i said i did not take out the throw out bearing is that the problem. if it is what do i replace it with? its almost like it is wabeling form left to right when i tighten down one side. like something in the middle is putting pressure on it.
torinostroker is offline
Old 02-29-2012, 08:43 AM
JMD
JMD's Avatar
Two possible issues that I can think of...
a. the torque converter snub is not seating in the crankshaft recess
b. (more likely) the T/Q is still not seated fully into the transmission. A C-4 TQ will need to "drop" twice. Been there and done that even when I knew better.... just two weeks ago, I had the trans out of a big *** Suburban and..............
JMD is offline
Old 02-29-2012, 10:25 AM
67t5ponycoupe
67t5ponycoupe's Avatar
I thnk you mean that you didn't take out the pilot bearing in the back of the crank. That has to come out to run an automatic. The torque converter needs to seat in there.
67t5ponycoupe is offline
Old 02-29-2012, 11:57 AM
scootchu
scootchu's Avatar
That's the first thing that came to mind, pilot bearing still in crank.
scootchu is offline
Old 02-29-2012, 04:03 PM
torinostroker
yah srry the pilot bearing and cool i am going to figure it out today i will take out the pilot bearing and try it. and the T.Q did drop twice made sure ha dint want to mess up my brand new one thx guys
Old 02-29-2012, 04:06 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yeah if your pilot bearing is still there thats your problem...pack it pull of grease in the hole and tap a wooden down and it will pop it right out of there
rmodel65 is offline
Old 02-29-2012, 05:53 PM
scootchu
scootchu's Avatar
I used a socket extension and toilet paper this past weekend. That works too. Use new toilet paper, no need to cheap out.
scootchu is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
mustangheaven
09-29-2015 11:00 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: bell housing wont bolt to block flush
