What headers work best with....
Old 03-02-2012, 09:27 PM
heckys67
heckys67's Avatar
Default What headers work best with....
Hey guys what headers are a good option I got a set of after market cylinder heads that have I believe 45 degree angle spark plugs would any kind of headers work? or do I need specific ones that will work for that certain application.
heckys67 is offline
Old 03-02-2012, 10:51 PM
Starfury
Starfury's Avatar
What heads did you get? The only common heads that require specific headers are Ford GT40P heads and aftermarket high-port heads.
Starfury is offline
Old 03-05-2012, 08:54 PM
frdnut
frdnut's Avatar
Some dart heads require a specific header as well..Normal headers will bolt up ok but you cannot remove the spark plugs with the headers in place...You will also want to check the size of the ports and get headers that will fit properly and not block off part of the port and hurt exhaust flow...Like Starfury said though the name of the heads is necessary before anyone can guess what you may need.
frdnut is offline
mmbrown
09-08-2015 01:29 AM
teeeeg67
09-01-2015 11:53 PM
GimpyHSHS
08-29-2015 06:30 PM
cema93
08-10-2015 09:35 PM
08-10-2015 02:02 PM
Quick Reply: What headers work best with....
