Plug weld cutting HELP
Old 03-10-2012, 09:06 AM
palerider
palerider's Avatar
I've had good luck with the blaire - I replaced a buch of panles (cowl, rockers, floor trunk drop, firewall, qtrs,etc.) and maybe used a 1/2 dozen bits- Mostly because I like to keep them sharp. Just buy a pack of replacements and you will be fine. Sounds like there are a lot of other good choices.
palerider is offline
Old 03-10-2012, 10:12 AM
JMD
JMD's Avatar
I just use drill bits.... 5/16" will get most spot welds, 3/8" will get most of the others...
I never saw much value in cutting around the spots when a new panel is going in anyway...
JMD is offline
Old 03-10-2012, 07:01 PM
LynnBob Mustang
LynnBob Mustang's Avatar
I've use Blaire's an have gone through only three bits doing tail light panel, trunk brace, rockers, quarters, floors pans, etc. and have good luck with them.
I'm not sure why a lot of you people have had bad luck with that style???
Lynn
LynnBob Mustang is offline
Old 03-10-2012, 07:59 PM
OkBrent
OkBrent's Avatar
You guys are behind the times...I have used those little cutters and they were slow and wore out fast. Do your self a favor a buy a Spot Weld Mill. This thing EATS up the weld fast with no pilot hole and you can set the depth so it only goes through the first panel. Has a ton of torque. Works Fast! One of the coolest tools I have. Brent
http://www.htpweld.com/products/auto.../index.htm#HTP Spot Mill
OkBrent is offline
Old 03-10-2012, 09:10 PM
scootchu
scootchu's Avatar
$249?! Wowee. I spent $28 for 4 bits and did all I needed to do.
scootchu is offline
Old 03-11-2012, 09:32 AM
mr_velocity
mr_velocity's Avatar
Damn, if I would have known about this 2 years ago there'd be one in my garage. I'm a sucker for great tools.
mr_velocity is offline
Old 03-11-2012, 02:45 PM
OkBrent
OkBrent's Avatar
I Know its not cheap, but time can be money and this thing is fast and you don't have to grind down the weld that is left on the panel from the hole cutter, and its cool. I justify it because I will have it forever. Brent
OkBrent is offline
Old 03-12-2012, 05:47 AM
dmaclaren
dmaclaren's Avatar
So I assume even though it speaks about spot welds, it will do the plug weld just as clean as the spot weld?
dmaclaren is offline
Old 03-12-2012, 09:01 AM
kenash
kenash's Avatar
Hi,
I'll offer this, I tried all of the aforementioned cutters and found the best to be "Roto-Broach" by Blue Diamond, a provider to Snap-On. They are hole circle cutters with a center locating pin. They come in a kit ranging in size from 3/8s to 3/4"s. I've cut hundreds of plug welds and are still use today. I paid about $90 10 years ago.
Just an alternative.
kenash is offline
Old 03-12-2012, 01:21 PM
groho
groho's Avatar
I too have used various bits, found Blair to be the most convenient, easiest to locate replacement bits, but has a tendancy to break teeth, fix that by not pressing so hard. The other bits are very nice, but pricey. My S&H only lasted 40-50 cuts before dulling, and had a tendency to cut too deep. Alway center punch the weld before you cut, it prevents the bit from travelling. I agree with Kenash, the Rotabroach is probably the best. Only prob, you likely have to order it.
groho is offline
BOB ROME
07-26-2023 01:54 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
mdg
10-01-2015 07:04 AM
Quick Reply: Plug weld cutting HELP
