hydraulic clutch and brake booster problem
Old 03-11-2012, 03:50 PM
chrismack
chrismack's Avatar
Default hydraulic clutch and brake booster problem
I have a 1967 Mustang that I have purchased the modern driveline, tko with the hydraulic clutch system.
The problem I have is my power brake booster is in the way of the hydraulic clutch linkage.
Has anyone else had this problem?
how did you fix it?
I tried to buy NPD's mini booster for my brakes, however it is the same size as my 9" booster.
I thought it was packaged wrong, so I had them pull another it was the same size.
Any ideas?
chrismack is offline
Old 03-11-2012, 06:24 PM
JMD
JMD's Avatar
How about a picture....
I am having trouble "seeing" the problem.
JMD is offline
Old 03-12-2012, 01:20 PM
chris66dad
chris66dad's Avatar
You can make a bracket that goes on the clutch pedal and and offsets the hydraulic clutch master cylinder to give you room to clear the power brake booster.
It will take some experimenting but can be done.
Here are pictures and a write up for for a 67:
http://www.dabbles-n-doodads.com/Mustang/clutch.html
My 66 NON power brakes was much easier:
http://chris66dad.tripod.com/id32.html
chris66dad is offline
CarrieS
09-01-2015 01:00 PM
whatsup62
08-29-2015 01:25 PM
FD725
08-23-2015 06:43 AM
FD725
08-11-2015 03:43 AM
Quick Reply: hydraulic clutch and brake booster problem
