1970 Mustang - Will Not Start
I am looking for tech guidance from Mustang people.
My 1970 Mustang will not start after sitting for two months in my garage.
- 302 with A/C
- C-4 Transmission
- All original wiring
The last time it started, it sounded like the starter remained engaged with the fly wheel even though the engine was started. I pulled the center coil on the distributer to kill the engine (and hopefully avoid destroying the starter...which may have happened anyway).
Now when I turn the ignition key I hear a single click/thud...and that is it.
Battery is brand new, starter solenoid is brand new.
I am grateful for the guidance
- 302 with A/C
- C-4 Transmission
Out of curiosity, I removed the new starter solenoid and re-installed the old starter solenoid. With the new battery installed, I jumped the the Mustang after revving the second vehicle up to 2,000 rpms.
After several attempts and very slow cranks, the Mustang started and ran for about 3 minutes with the jumper cables connected to the second vehicle.
When the Mustang was turned off (jumper cables still connected and second vehicle still running) and then turned ignition key to attempt to start, the Mustang would not start. It would slow crank but not start.
Well you've eliminated the battery and solenoid from the equation so...
Just a thought: it could be a weak ground from the starter (or weak internal ground if its one wire), try cranking down on it.
The alternative is a weak/busted starter which is a much more likely case given the situation
Other than that, I've got nothing
-Kirk
-Kirk
As always, this forum provides excellent and accurate guidance and support.
For those interested - The Mustang is running strong. I replaced the battery because it would not hold a charge. I also replaced the starter (it was toast) and the ground wire from the starter to the solenoid.
It fires right up without a problem.
Thank You again for the assistance fellow Mustang lovers.
-Gun
ShaneB26154
35
03-04-2021 04:05 AM
KEM Motorworks
08-14-2015 10:13 PM
'stangdude
08-12-2015 01:27 PM
mustangsrforever!!!
08-06-2015 12:04 PM
