Prevent the hood from opening - MustangForums.com
Old 03-23-2012, 12:52 PM   #1
_Remi
_Remi's Avatar
Default Prevent the hood from opening
Hi all,
I am looking for a way to lock my hood like on modern cars. I would feel better if it was not possible to open it without a key or without cranking up a lever from the inside of the car.
I am not looking for hood pins, just a nice/simple way to prevent my hood from being open by a random stranger on a parking lot
Thanks,
_Remi is offline   Reply With Quote
Old 03-23-2012, 09:27 PM   #2
Jonk67
Jonk67's Avatar
I have 2 and use both or either. I started with a gun cable lock, the hood will open just enough to get the key in and it hangs from the hood on the '67. I looped it through the hood part and lock it around the grill part where the hood latches.
The other is a cabinet lock that I drilled a hole for, the tumbler tab keeps the lever from moving to unlatch the hood. I can just get the key to it to unlock. Got this idea from another forum, this is his pic I saved. I used a cabinet lock from HD but will replace with a stronger one from a locksmith or cabinet co. as this one is China cheap.
Jon
Jonk67 is offline   Reply With Quote
Old 03-23-2012, 11:12 PM   #3
andrewmp6
I have heard of people using the hood latch off a 80s f150 but i haven't seen any pictures tho.
andrewmp6 is offline   Reply With Quote
Old 03-24-2012, 01:05 AM   #4
Cruzzar
Cruzzar's Avatar
The remote operated hood latches from the 80's Ford trucks will directly switch out with the stock latches on the '69/70 Mustang but I think the 67/68 Mustang uses a different latch assembly. The '69/70 Mustang latch is mounted on the radiator support whereas your latch is mounted on the bottom of the hood.
Cruzzar is offline   Reply With Quote
Upgraded PaulH2 Members Rides and Car Show Section 20 01-31-2016 09:48 AM
1994-1995 ODBII Port Urambo Tauro 5.0L (1979-1995) Mustang 6 10-05-2015 09:37 PM
Reminder - Steeda Pony Wars October 17th tj@steeda Florida Regional Chapter 0 09-30-2015 08:04 PM
Clear codes on '94 sn95 BOB ROME 5.0L (1979-1995) Mustang 2 09-28-2015 11:10 AM
V6 Project Problems ThatJuanStang V6 (1994-2004) Mustangs 4 09-25-2015 08:01 AM
67, 68, assembly, change, hood, issues, latch, lever, locking, mustang, mustangs
