PCV and Breather - MustangForums.com
Old 04-01-2012, 10:48 PM   #1
oxfordbp
Default PCV and Breather
Why would I need a PCV valve? Cant I use a breather on the intake to do the same thing? A breather that has a hose fitting to my carb.
oxfordbp is offline   Reply With Quote
Old 04-01-2012, 10:50 PM   #2
cheapstang68
I would, I took mine of.
cheapstang68 is offline   Reply With Quote
Old 04-02-2012, 01:13 AM   #3
andrewmp6
Both do the same job the breather system is older then the pcv system tho.
andrewmp6 is offline   Reply With Quote
Old 04-02-2012, 01:21 AM   #4
oxfordbp
Quote:
Cool thanks
Old 04-02-2012, 01:27 AM   #5
Starfury
Um, no. You need a functioning PCV system to evacuate corrosive gases from the crankcase. And you can't simply plumb a hose from a breather to full manifold vacuum at the base of the carb, or you'll just have a really big vacuum leak. You need that PCV valve in between to meter the airflow down a bit. The breather goes on the opposite valve cover to vent gas into the crankcase.
On most street vehicles, there is no reason not to run a PCV. It doesn't hurt anything, and it helps extend engine life.
Starfury is offline   Reply With Quote
Old 04-02-2012, 01:37 AM   #6
67t5ponycoupe
PCV will also prevent a backfire from sending fire down into your crank case and causing damage. You should always run a PCV
67t5ponycoupe is offline   Reply With Quote
Old 04-02-2012, 03:24 AM   #7
oxfordbp
I will run a Pcv valve on my new setup.
Which year should I use??
Old 04-02-2012, 09:24 AM   #8
Starfury
Personally, I use a PCV from a common Chevy application, simply because it has a 90* fitting attached to it. I think it works on mid-80's chevy pickup 350's.
Old 04-02-2012, 06:15 PM   #9
oxfordbp
Quote:
I got one with a 90 in it! thanks. Do you know where it should hook up on an edelbrock 1405? Front or rear?
Old 04-02-2012, 06:16 PM   #10
oxfordbp
Also does it matter what side valve cover I hook the PCV to? I would think not as long as the opposite side has a breather, right?
95 gt dead fuel pump?? 9550 5.0L (1979-1995) Mustang 10 10-26-2015 06:01 PM
Slight surge at 1500ish rpm lmurf60 4.6L (1996-2004 Modular) Mustang 1 09-24-2015 11:07 PM
Question about Valve Cover Breather Ipaman 5.0L (1979-1995) Mustang 12 09-22-2015 08:01 AM
High idle after cleaning Imrc Scottyboy187 SVT Forums 1 09-13-2015 11:23 PM
EFI to CARB conversion problem, running like a PIG..vacuum problem? YoungStangsMan 5.0L (1979-1995) Mustang 15 09-05-2015 08:01 PM
1405, 1967, 1968, 302, breather, breathers, coupe, edelbrock, hood, hook, mustang, pcv, pvc, run, side, thing, v6, valve
