wood carb spacers - MustangForums.com
Old 04-05-2012, 07:49 AM   #1
Toastintx
Default wood carb spacers
are wood carb spacers any good, i mean do the hold up or will they deteriorate
Toastintx is offline   Reply With Quote
Old 04-05-2012, 02:10 PM   #2
69mach1377
69mach1377's Avatar
Wood will absorb fuel and may catch fire. There were wood looking ones made of a composite of some sort as well as black ones and aluminum spacers that are better.
69mach1377 is offline   Reply With Quote
Old 04-05-2012, 02:18 PM   #3
Toastintx
Well the one I have is from Summit Racing, its an Edelbrock wood spacer
Old 04-05-2012, 09:53 PM   #4
JMD
JMD's Avatar
I have heard they work fine and are actually very good at insulating the carb from the manifold.
Would I sport one? IDK, I think I would so long as it wasn't left in natural finish.
It would bug me if I ever got asked why I have wood parts on my engine.. and "did all cars built in the 60s have wooden engine parts??
FWIW, if I had already bought a wood spacer I would try it for sure. (but I would paint it).
JMD is offline   Reply With Quote
Old 04-05-2012, 11:26 PM   #5
musnicki
musnicki's Avatar
I have an aluminum one. I put on a spacer to keep heat off of my carb. The wood one probably would do a better job and keeping heat from the manifold to the carb. My carb still gets kinda warm and it bugs me.
musnicki is offline   Reply With Quote
Old 04-05-2012, 11:39 PM   #6
Toastintx
well this "wood" spacer doesnt look like wood, and i guess its probably as odd as putting phenolic on an engine! I'm just hoping that it holds up and doesnt deteriorate. lol
Old 04-06-2012, 12:06 AM   #7
eZ
eZ's Avatar
Phenolic > aluminum
eZ is offline   Reply With Quote
Old 04-06-2012, 04:13 AM   #8
kalli
musnicki: aluminum is about the worst you could possibly do to keep heat away from the carburetor. metal has a very high heat conductivity.
If you need to keep heat away get a phenolic spacer!
I have that one with open gasket at bottom and square bore gasket on top
http://www.summitracing.com/parts/EDL-8711/
obviously make sure the shape matches your carb and intake.
as for wood spacers, as long as they make phenolic ones, I don't see the point.
They won't soak up with petrol and water like wood would.
I think would will work, but for longetivity they are probably crap.
they would soak water and first winter they'd crack. you'd be chasing vacuum leaks forever. I think they were the cheap mans spacer when you could just make another one next week ...
kalli is offline   Reply With Quote
Old 04-06-2012, 06:27 AM   #9
andrewmp6
I believe they are made from press wood so it won't act like real wood will.
andrewmp6 is offline   Reply With Quote
Old 04-06-2012, 09:42 AM   #10
Starfury
I had a fiber/composite spacer, which is what I suspect you have rather than a piece of wood. It worked well for insulation, but eventually compressed and warped and I ditched it for a phenolic spacer.
Starfury is offline   Reply With Quote
Vintage AC shop referral - frontrunner serpentine system bradleyb Classic Mustangs (Tech) 3 11-27-2015 08:50 PM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 02:02 AM
66 Mustang Dying Sminemann Classic Mustangs (Tech) 7 09-17-2015 10:24 AM
New 5.0 carb build bogs at hit of throttle Daddys Girls GTs 5.0L (1979-1995) Mustang 3 09-14-2015 09:46 PM
Noob needs help! 86 mustang svo motor swapped to 71 5_speed carb 302 v8 jaiidutch Motor Swap Section 2 09-14-2015 11:29 AM
car, carb, carburetor, eng, fire, high, make, mpg, mustang, performance, phenolic, spacer, spacers, test, wood
