69 351 w spark plug gap .032-6 or .042-6 - MustangForums.com
Old 04-22-2012, 12:00 PM   #1
dmaclaren
Default 69 351 w spark plug gap .032-6 or .042-6
I have read both and in pulling all my plugs, they are in the .042 - 6 range.
Are my gaps off from the previous owner or is that right? it's a 1969 351w
dmaclaren is offline   Reply With Quote
Old 04-22-2012, 02:55 PM   #2
BuckeyeDemon
the shop set mine at .030" lots of people run .035".
the bigger the gap, the higher the voltage, which i would expect to be harder on wires/caps/rotors.
BuckeyeDemon is offline   Reply With Quote
Old 04-22-2012, 04:41 PM   #3
dmaclaren
I'm running electronic ignition, I have them gaped at .046, wonder if I should reduce to the .036. I was just reading that for elec. ign., .04x is the way to go.
Now I am not sure
Old 04-22-2012, 04:49 PM   #4
BuckeyeDemon
there seems to be a love affair with increasing the gap with a more powerful ignition system. i personally don't understand the rationale. maybe someone here will explain it to me.
Old 04-22-2012, 10:22 PM   #5
The_Dude
I run .045 with an electronic ignition and .036 with points. The bigger gap allows for a bigger fatter spark. An electronic ignition has more volts to jump the larger gap.
The_Dude is offline   Reply With Quote
Old 04-22-2012, 10:43 PM   #6
musnicki
musnicki's Avatar
I have mine at 40, NGK plugs with MSD 6AL box. I don't notice a difference, I was told between 35 and 45, so I set it at 40. A bigger spark makes for a more complete burn I guess?
musnicki is offline   Reply With Quote
Old 04-23-2012, 12:30 AM   #7
Starfury
It helps ignite the mix more reliably. GM HEI systems (which use ~100kV coils) are commonly run with a .050-.060" gap.
With a stock coil and electronic ignition, I'd say .035". With an aftermarket 40kV coil, call it .040.-.045".
Starfury is offline   Reply With Quote
what are the odds - Service Engine Soon light lincolnshibuya V6 (1994-2004) Mustangs 9 12-08-2015 04:37 PM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 05:52 AM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 01:27 PM
Clear codes on '94 sn95 BOB ROME 5.0L (1979-1995) Mustang 2 09-28-2015 11:10 AM
Slight surge at 1500ish rpm lmurf60 4.6L (1996-2004 Modular) Mustang 1 09-24-2015 10:07 PM
04, 1969, 351, 8mm, cobra, gap, gapping, ignition, msd, mustang, oem, plug, plugs, proper, size, spark, windsor, wires
