Door alignment- slight twist
Old 04-29-2012, 12:06 PM
palerider
palerider's Avatar
Default Door alignment- slight twist
I seem to remember a post a while back describing how to remove a couple welds and do a slight twist to get doors line up. Got mine pretty close but driver side sticks out at the bottom latch side and in on bottom hinge side. Been playing with it but can't get exactly right. Does this ring a bell or any suggestions?
palerider is offline
Old 04-29-2012, 04:27 PM
MustangsToFear
MustangsToFear's Avatar
If it is a aftermarket door, and you have used all the adjustments in the hinges, then bust the 2 spot welds at the top of the door where the vent glass goes in. Then twist the door to get the fit you want a re weld the tab.
MustangsToFear is offline
Old 04-29-2012, 06:11 PM
Coupe
Coupe's Avatar
I twisted mine without messing with the welds, but I have not installed my glass yet.
Coupe is offline
Old 04-30-2012, 06:45 AM
palerider
palerider's Avatar
I'm assuming these are the tabs you are referring to? Also did you have any problems with glass after doing it?
Old 05-01-2012, 06:08 AM
MustangsToFear
Yes, those are the tabs. Just make sure you don't squeeze the outer door skin so tight that you can't get your vent frame in.
Old 05-01-2012, 06:40 AM
palerider
palerider's Avatar
Thanks - I'll keep that in mind.
jerrytubes
10-23-2015 12:11 PM
Dokilar
15
10-16-2015 08:13 PM
09-25-2015 06:58 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Door alignment- slight twist
