351/400M vs the 351w and 351c
Old 04-30-2012, 05:53 PM
craig71springsport
craig71springsport's Avatar
Default 351/400M vs the 351w and 351c
I'm aware of the advantages of the Windsor and Cleveland blocks...but how about those Michigan blocks?
craig71springsport is offline
Old 04-30-2012, 07:47 PM
BuckeyeDemon
BuckeyeDemon's Avatar
i remember my cousins trying to build a dirt late model back in the very early 90's based on a M block. they took four blocks to a machine shop and they all apparently had thin spots on the cylinders and recommeneded not using them as a foundation for a high performance engine.
BuckeyeDemon is offline
Old 04-30-2012, 08:36 PM
ebourd
ebourd's Avatar
Yeah a 460 is a way better big block the modifieds are half small block half big block I had a few of um a lot of part from Cleveland and Windsor are interchangeable but not worth the trouble
ebourd is offline
Old 04-30-2012, 08:44 PM
TexasAxMan
TexasAxMan's Avatar
I thought the M blocks were Mexican made and of pretty high quality ...
TexasAxMan is offline
Old 04-30-2012, 08:45 PM
JMD
JMD's Avatar
The M motors can make good power if built right, they use the big bell housing so they wont bolt to a C-4, and I don't think they will bolt to an AOD either.
Speed equipment will cost more than for either a W or a C, IMO a little too cumbersome to use in a Mustang when better (more economical) choices are available.
JMD is offline
Old 05-01-2012, 10:41 AM
69mach1377
69mach1377's Avatar
I don't think the M stood for Michigan or Mexican.
IIRC, Modified or Milliford?
In any case, I've not seen any write ups on performance 351/400M engines. They served time for trucks and heavy cars for the most part, so low end torque might have been there.
69mach1377 is offline
Old 05-01-2012, 11:52 AM
ebourd
ebourd's Avatar
It stands for modified and mine was bolted to a c4 in a ranchero and big bell housing
ebourd is offline
Old 05-01-2012, 05:31 PM
craig71springsport
The M stands for Michigan, where they were made. They were made in Michigan and the CCP (Cleveland Casting Plant.)
Well if I ever get to do my F-100 build that I so desperately want to do, I'll just punch out a 400 and make myself a 408! Gonna stick with the Windsor family for the stang, though. Thanks guys.
Old 05-01-2012, 05:37 PM
2+2GT
2+2GT's Avatar
The M uses the motor mounts and bellhousing of the 429/460, which makes it a real pain to install in a Mustang.
2+2GT is offline
Old 05-01-2012, 05:59 PM
JMD
JMD's Avatar
The weakness in the M motors was their low stock compression ratio, about 7.5 to 1 or maybe 8 to 1. I have also READ that they don't oil that great.
I know for sure that the tops of the pistons (in stock configuration) lack quite a bit reaching the top of the cylinders. At TDC they remain perhaps 3/16" down in the bore.
Even stock parts are RELATIVELY hard to find and pricy.
I have read about a few of them doing quite well in HOT ROD's pump gas engine build offs. They DO have potential, but it is a much harder (and more expensive) row to hoe than building a Windsor.
JMD is offline
Quick Reply: 351/400M vs the 351w and 351c
