Gas pedal linkage, pedal, hesitation/sticking
Old 05-01-2012, 07:06 AM
dmaclaren
dmaclaren's Avatar
Default Gas pedal linkage, pedal, hesitation/sticking
Okay, below is the picture of the 69 mustang gas Pedal. Look a the area that the bent metal bar goes through the clamp.
My pedal has gap between the connector areas and it can float left/right. This one is tight to the mount/bushings.
So, my pedal is smooth when car is off and in neutral. But when I drive it, the first part of the pedal there is this stick point. So, when driving normal, non partially aggressive, there is this stick/dead point.
Now, before I buy a full $75 pedal, is there anything that I should look at? I would say it's the issue with the part that goes through the mount if it wasn't so smooth when not driving. I have a feeling that if it's not the way it looks here in the pic, I have to suck it up and buy it set up right. But I wanted to exhaust options.
dmaclaren is offline
Old 05-01-2012, 01:15 PM
cheapstang68
cheapstang68's Avatar
I had the same problem, but I figured out that the linkage was the issue. It was to tight on the pedal rod and to tight on the carb. Maybe try adjusting the linkage before spending the money? Just a thought.
M
cheapstang68 is offline
Old 05-02-2012, 05:30 AM
dmaclaren
dmaclaren's Avatar
M
Thanks, will give it a try. The linkage at the pedal is non adjusting but I will look at the carb when I get it back on Thur. I can't remember the full set up there.
Old 05-02-2012, 12:25 PM
68dustin
68dustin's Avatar
M
HAD THE SAME PROBLEM! ended up i had the linkage at the carb too tight.
68dustin is offline
4cylinderplus2
10-09-2020 07:45 PM
Thunderball
15
11-22-2015 11:49 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Gas pedal linkage, pedal, hesitation/sticking
