T5 conversion, Question on driveshaft - Page 2 - MustangForums.com
Old 05-11-2012, 08:47 PM   #11
KidsStang
Yeah thats what I thought, I can understand if the yoke was inserting too far into the trans tailshaft, but if the shorter driveshaft corrects this then why get one.
KidsStang is offline   Reply With Quote
Old 05-11-2012, 11:31 PM   #12
Gun Jam
Moderator
Gun Jam's Avatar
Quote:
Originally Posted by 2+2GT View Post
You need a new slip yoke because the parts suppliers want to sell you one. Glazier/Nolan checks whether you need one before telling you to shell out $100.
No you need a new slip yoke because the old one is worn where is rode on the TS bushing and is a possible source of vibration.
You need a new TS bushing for the same reason. My experience has been that the TS bushing compresses a bit due to its manufacturing process when inserted into the TS housing. In my case for for proper fit the bushing had to be honed using a brake cylinder hone. Now you slide in that old slip yoke and its proper tolerance unit it reaches the wear mark and now its a sloppy fit.
Go on roll the dice you might get lucky...a number of us do but when you dont get lucky it sucks. The time and money I spent hunting down these issues I could have bought about 2 new DS from dennys.
Gun Jam is offline   Reply With Quote
Old 05-12-2012, 07:36 AM   #13
2+2GT
That's why you might need a new yoke. My problem is with those who force you to buy one, by telling you it's a "T5 yoke, required for conversion".
I have never needed to hone a tailshaft bushing. Typically, the tailshaft bushing can be installed with the trans in the car, without disturbing the tailshaft housing. The whole job takes about 2 hours, with the right tools.
2+2GT is offline   Reply With Quote
Old 05-12-2012, 10:47 AM   #14
Gun Jam
Moderator
Gun Jam's Avatar
+1
That's a load nothing is "required" In fact the real t5 slip yoke wont even fit the classic style DS as it uses a different U-joint I recall.
-Gun
Old 05-13-2012, 10:27 PM   #15
QuickV8
i didnt cut mine either or change the york.
QuickV8 is offline   Reply With Quote
Old 05-18-2012, 03:35 AM   #16
synthartist69
Quote:
Originally Posted by KidsStang View Post
Hello, Anyone out there with a T5 conversion, did you have to cut down your drive shaft, how much? Did you keep your yoke or buy an aftermarket, I tried to install the driveshaft last weekend and it would probaly work but there was little to no extra yoke left, probaly too tight right?
I chose to buy a new driveshaft to save time and hassle. You will love this conversion!
synthartist69 is offline   Reply With Quote
BMR Suspension, DSS, Barton and Viking Performance all going in today!! Boostaddict 2.3L Eco-Boost Tech 2 11-24-2015 07:11 AM
window tint issues? chrisdbassplayer 2010-current S197 Appearance Section 4 10-13-2015 07:53 PM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 08:16 AM
Hello, new user with an older Mustang and a question treesloth New Member Area 4 09-28-2015 08:03 AM
Pinion angle, poly bushings, 1 piece DS mtgldr S197 Handling Section 1 09-10-2015 10:43 PM
95, balance, classic, conversion, cut, drive, driveshaft, leaking, mustang, north, oil, shaft, swap, t5, texas, v6, yoke
