More flickering headlights - Page 2 - MustangForums.com
Old 05-23-2012, 03:45 PM   #11
guitarman376
I was thinking of buying from mustangplus, mustangsunlimited, mustangbarn, or one of the other restoration parts suppliers.
guitarman376 is offline   Reply With Quote
Old 05-23-2012, 03:51 PM   #12
jlg2002
jlg2002's Avatar
this is a good starting point for you:
http://www.mustangmonthly.com/techar...ich/index.html
jlg2002 is offline   Reply With Quote
Old 05-23-2012, 07:56 PM   #13
guitarman376
That article is helpful, hopefully I can find that tool they use. Thanks again, there is a reason I have been a member for 5 yrs!
Old 05-27-2012, 04:48 AM   #14
tx65coupe
tx65coupe's Avatar
Once you get your lights working properly, consider installing some relays. I have thus setup. You can also make your own. It will take the load off of the switch as well as supply more voltage to the bulbs giving you brighter lights.
http://www.rjminjectiontech.com/prod...dlight-harness
tx65coupe is offline   Reply With Quote
Old 05-27-2012, 04:11 PM   #15
guitarman376
That is a great idea too, I'm putting that on "the list"
Old 05-27-2012, 08:35 PM   #16
dklistul
If they're blinking off and on intermittently, I'd agree about the switch.
But you also said they're going brighter than they ever have before. That can only be caused by high voltage at the headlamp and THAT can't caused by the switch. The switch can reduce current through high resistance contacts, but it certainly can't manufacture any more volts. I know you checked your battery voltage but still, my bet for the overly-bright lights is an intermittently sticking cutout relay in the regulator (I'm assuming it's an electro-mechanical regulator, not a solid-state unit).
dklistul is offline   Reply With Quote
Old 05-30-2012, 04:36 AM   #17
guitarman376
I have to replace the dash light bulbs anyways, so doing the headlight switch at the same time isn't too much extra work it seems. I have a regular stock external regulator, and the lights DID use to dim (they do not anymore...). I figure eventually I will want to slowly rewire my car so doing the switches now saves me any future hassles.
Thoughts on one piece headlights... StalkerGT 5.0L General Discussion 19 11-28-2015 04:09 PM
2007 Won't stay running -- Possible electric problem Seanam V6 S197 General Discussion 5 10-04-2015 11:15 AM
better way to attach headlights Drastang 4.6L (1996-2004 Modular) Mustang 3 09-29-2015 04:31 PM
Weird electrical/battery issue?? Mobiusone stang 2005-2014 Mustangs 7 09-07-2015 09:46 PM
'11 to '13 tail light swap amandahchase General Tech 0 09-03-2015 11:09 AM
2013, 69, bright, dim, flicker, light, mustang, shelby
