Tire Emergency - Order Ships Tomorrow
So after looking at tire reviews and other pics on the ride height/setup page I ordered a set of the following:
4x - Firestone Firehawk Indy 500 235/60/15
My concern is that I just saw some posts mentioning that that size was a tight fit in the back.
Will I have issues getting these on in the front and back?
What if my stock suspension is sagging slightly or I lower and inch in the front and back?
I am ordering 15x7 Magnum 500s and the other size I was looking at was 215/65/15. I also see people saying that that size is too big for a 7inch wheel.
I need to move quick as these tire are being discontinued despite the rave reviews on tirerack (esp compared to the Radial T/A).
People seem to say at that size with a 7inch rim they will basically be bubble on the side which will cause wear and handling issues.
Panicked...changed the order to 215/60/15 x 4
Probably would have been fine since I think its the 65-66 you have to be more concerned about but hated the idea of tire damage or excess wear since I want to plan some very long road trips.
These two links helped a lot
http://www.rimsntires.com/specs.jsp
http://www.miata.net/garage/tirecalc.html
I think if I could do it again I would do 225/60/15 which people say fits all around but they did not have it for the tire I wanted. I want 4 of the same size as I will likely buy a spare if I do any long trips (planning a NYC to SF trip for next year).
I have the Firehawk's on my GS Villager 215/55/15 one was defective and I returned it.
My steering wheel was shaking and I knew I needed rack&pinion and inner & outer tie rod ends, $700.00 repair. And yes Firestone is discontinuing the Indy 500.
They'll look great on your classic Stang! Jusy watch them for defects when you first
drive them.
drive them.
the 215/65's are about the same diameter as a 235/60
the recommended rim width's for the radial T/A's are located here:
BF Goodrich Radial T/A
the recommended rim width for a 215/65 is 6-7.5"
a 235/60 is 6.5 to 8.5"
