another 66 turn signal question
everything was working fone. O have had no problems since i replaced my signal switch in the column. However, I noticed the other day that the dash signal indicator light was not working. Also, the front signal light is not working either. The back however is working fine (this is on the right side only, the left is fine)
What would cause the rear indicator to work but not the front or the dash lights. I did notice a small grinding sound in the column but it went away...
THanks
THanks
