Shifter linkage not returning to neutral on 1971 three speed
Old 06-02-2012, 03:11 PM
Gasoline
Gasoline's Avatar
Default Shifter linkage not returning to neutral on 1971 three speed
Hello!
I have a 1971 fastback with a three speed manual transmission.
I have owned it for six years whitout any real problems, but recently one of the two shifter linkage (the one to the right) stopped returning to neutral when I change gear from first to second.
I happens sometimes and the result is that I have to drive it on first gear to the garage and then crawl under the car and manually push it.
Any ideas?
Thanks,
Thomas
Gasoline is offline
Old 06-02-2012, 03:40 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
worn out bushing or out of adjustment shift lever
rmodel65 is offline
Old 06-02-2012, 03:47 PM
Gasoline
Gasoline's Avatar
Maybe they are called shifter rods. Here is a picture:
http://www.mustangmonthly.com/howto/.../photo_02.html
Gasoline is offline
Old 06-02-2012, 04:05 PM
Old Mustanger
Old Mustanger's Avatar
I would start with rebuilding the shifter and replacing any shift rod bushings that are replaceable. There should be kits available if you look around.
Old Mustanger is offline
Old 06-02-2012, 04:51 PM
Starfury
Starfury's Avatar
Agreed. Rebuild the shifter with a 4 speed rebuild kit. The 4sp kit from Glazier's comes with better hardware and will work on the 3sp shifter.
Once you're done, readjust the shift linkage per the factory shop manual.
Starfury is offline
Old 06-02-2012, 05:14 PM
Gasoline
Gasoline's Avatar
OK, so I would come a long way with new rod bushings?
Would this kit do the trick? http://www.drakeautomotivegroup.com/...7.aspx?wid=141
Gasoline is offline
Old 06-02-2012, 05:36 PM
Gasoline
Gasoline's Avatar
Do you mean this kit from Glazier/Nolan?
G06218 64½-73 3 speed shift lever Rebuild Kit, includes special mounting
bolts, grommets, trunnions and trunnion grommets, does not include
G07159 washers (2) needed for rebuild ..........................................$27.95
Gasoline is offline
Old 06-02-2012, 06:18 PM
Starfury
Starfury's Avatar
No, I mean the kit for the 4sp. Also, a set of the Mr Gasket/Hurst shift linkage bushings wouldn't hurt.
Starfury is offline
Old 06-03-2012, 02:15 AM
Gasoline
Gasoline's Avatar
Thanks,
I will get a closer look at the car today. I will start with cleaning the shifter rods, put it in neutral and run a 1/4 allen key through the alignment hole and see if it's adjusted correctly. http://www.ranchero.us/forums/showthread.php?t=7103
If it doesn't do the trick I will order the kit from Glazier/Nolan. It seems strange to order a 4-speed kit to a 3-speed. I will keep you updated.
Gasoline is offline
Old 06-03-2012, 11:50 AM
Starfury
Starfury's Avatar
It does, but it works.
Starfury is offline
Quick Reply: Shifter linkage not returning to neutral on 1971 three speed
