What Tranny do I need???
Old 06-27-2012, 06:37 AM
andrewmp6
andrewmp6's Avatar
The only safe way to do it is change all the suspension and drivetrain parts to the v8 ones,If not i wouldn't drive it even with front disc those spindles are smaller the front springs with the weight of a v8 it will be all over the road.Its cheaper to do it right the first time then to cut corners and end up doing it over again.
andrewmp6 is offline
Old 06-27-2012, 12:33 PM
wgc68nyc
wgc68nyc's Avatar
Auto -
AOD if you do any highway
C4 for reliability long term if its a cruiser
Manual
t-5 if for highway
4 speed if you are trying to keep it vintage-y
wgc68nyc is offline
Old 06-29-2012, 10:54 PM
GypsyR
GypsyR's Avatar
4R70W's are NOT exclusive the V6's. My 1994 F150 5.0 truck has one. I like 4R70W's but the extra $600+ for a controller is a bit much for my taste. The less expensive AOD's work fine for me.
The simplest solution is another C4. C4's are great transmissions but I'm addicted to having overdrive.
GypsyR is offline
Old 06-30-2012, 07:00 AM
andrewmp6
andrewmp6's Avatar
Only the v6 4r70w has the right bolt pattern for a small block,The mod motor has its own bolt pattern that will not work.
Old 06-30-2012, 06:08 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the explorer 5.0's used a 4r70w with a standard 302 bolt pattern...
rmodel65 is offline
Old 06-30-2012, 07:25 PM
mr_velocity
mr_velocity's Avatar
Controllers from Bauman are under $500. The newer 1998 - 2002 4R70Ws were stronger than the older version and can handle up to 500hp while the previous version were good up to 375hp.
You need to be careful with bolt patters, one out of a V6 will fit, one out a V8 mod will not. I paid $100 for my 4R70w, then sent it to FB Performance to have it gone through and setup to handle 600hp....just in case
mr_velocity is offline
Old 07-02-2012, 12:55 AM
JeffandMichelle Ritchie
JeffandMichelle Ritchie's Avatar
Default Need bellhousing swap....Help!!!
As I thought Bellhousing does not match up, surprise! I had the 200 inline 6 motor with c4 tranny... now i have the 5.0 HO 1983 302 motor... anyone know the bellhousing that i need to match up???? and where I can find one?? been searching web and it looks like they are out there, I just don't know which on to get...so many part numbers for this rookie....Help please!!
JeffandMichelle Ritchie is offline
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
prophotog
09-15-2015 08:38 AM
jaiidutch
09-14-2015 10:29 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: What Tranny do I need???
