What Tranny do I need???
The only safe way to do it is change all the suspension and drivetrain parts to the v8 ones,If not i wouldn't drive it even with front disc those spindles are smaller the front springs with the weight of a v8 it will be all over the road.Its cheaper to do it right the first time then to cut corners and end up doing it over again.
4R70W's are NOT exclusive the V6's. My 1994 F150 5.0 truck has one. I like 4R70W's but the extra $600+ for a controller is a bit much for my taste. The less expensive AOD's work fine for me.
The simplest solution is another C4. C4's are great transmissions but I'm addicted to having overdrive.
You need to be careful with bolt patters, one out of a V6 will fit, one out a V8 mod will not. I paid $100 for my 4R70w, then sent it to FB Performance to have it gone through and setup to handle 600hp....just in case
Need bellhousing swap....Help!!!
As I thought Bellhousing does not match up, surprise! I had the 200 inline 6 motor with c4 tranny... now i have the 5.0 HO 1983 302 motor... anyone know the bellhousing that i need to match up???? and where I can find one?? been searching web and it looks like they are out there, I just don't know which on to get...so many part numbers for this rookie....Help please!!
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
