Suspension Disappointment
What did I do??
After having my '68 coupe on jackstands for over a year while I rebuilt the suspension and did a power disc conversion, it was finally set back on the floor today.......which should have been a BANNER day.......but nooooooo.......I have apparently screwed something up. The stance is WRONG......the rear is sagging WELL below the front. I specifically tried to NOT let this happen when I purchased the parts. I don't have the part numbers in front of me at the moment but I will post them in a bit.
I installed a Grab-Trac-setup......new leaf springs, coil springs, upper and lower control arms, tie-rods and shocks.
Did I go wrong with the leaf springs? Since I bought all this stuff in September of 2010, I have to go dig up my receipt.....and it also means I can't exchange anything. Grrrrrrr......I learn EVERYTHING the hard and expensive way apparently.
Here is a pic taken today.....the stance looks MUCH worse in person.
Okay........Grab-A-Trak 620lb coil springs up front and Grab-A-Trak 4 1/2 leaf, mid-eye in the back.
Any ideas from the experts? It looks like I lowered the rear and raised the front???
Let the front settle. Drive it around for a couple months and see what happens. I really doubt it will stay that high. Keep in mind, those 4.5 leaf rear springs drop the rear well below stock ride height. Also, the factory stance was slightly raked back, rather than forward, like you would think.
Based on personal experience with that exact spring setup, as well as seeing several other Mustang owners with the same setup, the front will likely settle more than that...but not quite enough to even out the stance. My fastback still sits about an inch too high in the front for my liking (although lower than your car sits right now). One day, when I get the time, I'll be hacking 1/4 coil off each side. This has evened out the stance for several other people with this spring combo.
yup, let it settle and it should come down a bit. if you want to drop it more you could always relocate the upper a arms and that will bring it down another inch or so. but depending on what upper a arms you got you may need a wedge kit to prevent the ball joint from binding.
Thanks folks! It would have to settle a LOT to get to an even ride height........I'm kicking myself for not doing the Shelby drop while having everything off the car, FOR A YEAR.......DOHHHH..........idiot.
When I sat it down on the floor after all this time and the rear settled so low, I could have cried......broke my heart.....oh well....it's part of it I guess. I'm learnin'!!
