Electric choke hook up
I've used this wire to power a relay, and that does work well.
You know, that all makes sense, but when testing it with the meter, it was on and off with the key. Out pf curiosity, could this be because it has been switched over to an electric start set up? Car is at tranny shop for a day or so but will definitely test again when she comes home. Keep up the info...i need all.i can get!
OK, but I have Vintage Air (so the blower isn't where it should be) and have hidden as much of my wiring as possible. So do I have to run a separate wire just for the coil? In Houston the choke is only on for a very short while most of the year.
What is the problem with wiring it to the coil +?
It's not 12V. You want the choke to open as fast as possible, so you want to give it the full 12V. That's why I don't use the stator post on the back of the alternator. It's only 7V. A relay is dead simple to wire. Then you have 12V under the hood for anything you need.
mrappe
09-26-2015 10:16 AM
