Got some gremlins under my hood
Old 07-16-2012, 11:21 PM
69dude
69dude's Avatar
Default Got some gremlins under my hood
The title of the post pretty much says it, the 69 fired up after sitting for 10 years using some starting fluid to get it to life then no spark and now the spark is back and is temper-mental like a Italian car but when the fuel finally filled the bowls to the carb the fuel line was bad and was dumping gas on the ground like a water fall, so after changing the fuel pump cause it was bad too and new hard line and rubber lines trying and trying no fuel is reaching my new mechanical pump I blew air back into the intake line to try and clear it to the tank but nothin still. Should I just run a external tank for now so I could move it around on my property? or is there any more trick to get fuel to the pump. and yes the tank has 5 gallons of gas in it so that should be enough even for the low pick up
69dude is offline
Old 07-17-2012, 01:32 AM
andrewmp6
andrewmp6's Avatar
With it sitting that long with fuel in it i bet the main fuel line from the tank is clogged with rust.I would try that external tank if it runs fine off that then its the line from the tank or the pickup in the tank is clogged.
andrewmp6 is offline
Old 07-18-2012, 03:09 PM
69dude
69dude's Avatar
Thanks for the reply, I got it running finally with its current tank, I pressurized it from the filler cap and it shot all that gunk in the pick up out, still got a issuse with electrical, the stereo wont turn off and drains the battery and my coil is being dumb and works when it wants to its a older mallory which I like but hope I dont have to replace it
69dude is offline
Old 07-18-2012, 10:35 PM
andrewmp6
andrewmp6's Avatar
Well you got it running that's the big thing,But the extra stuff that pops up can be fun good luck with it.
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
11-18-2015 01:34 PM
Urambo Tauro
10-05-2015 09:37 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Got some gremlins under my hood
