Help with high compression motor
11.7 to 1 sounds like too much for a street car. Are you sure that is your compression ratio?
You will need to tune it on the fuel you plan to or need to run. Change the fuel and the tune will need to change.
I would start be setting timing closer to 0 at idle. I am concerned you will have detonation. Once timed at 0 read the full advance at 3000 rpm. I time my distributors at full advance and let the idle be where it falls. You will need to creep up to the max advance without pinging or risk damaging the engine. More advance makes more ping not less. Ping is the boom happening too soon.
for your reading
http://en.wikipedia.org/wiki/Engine_...g#Pre-ignition
http://en.wikipedia.org/wiki/Engine_knocking
for your reading
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
jaiidutch
09-14-2015 10:29 AM
