Need help with mustang not starting
Old 09-11-2012, 02:21 PM
Duba
Duba's Avatar
Default Need help with mustang not starting
Hey guys,
This sounds funny but I do my own work on the Mercedes but can't seem to figure this 1967 289 mustang coupe that my son and I have....
Can't seem to start it. It makes clicking noise coming from starter solenoid when we try to start it, so I replace it...a friend told me maybe the starter was frozen, so I replace it since it was the original. Still making the same noise after those items were replaced.
Need some direction, how to test or?? Don't want to just start replacing things. I have a new voltage regulator as well. New battery..etc...
Duba is offline
Old 09-11-2012, 03:22 PM
jlg2002
jlg2002's Avatar
clicking noises on start are usually a low battery or dirty/bad terminations either at the battery or the engine block/frame. or bad cables (excessive voltage drop)
jlg2002 is offline
Old 09-11-2012, 04:02 PM
Iskwezm
Iskwezm's Avatar
check for a bad ground
Iskwezm is offline
Old 09-11-2012, 04:56 PM
Duba
Duba's Avatar
This has p....ed my off. I have new cables, good ground. I looked at all voltage. I have found that in the past I have had problems with the Optima I bought. Less than 30 miles and the car sat for a long time. I went to have the battery replaced but out of warranty by 2 months. Threw in a battery from a donor Mercedes I had.
Looked at another old post where the guy had the same problem. Switched the battery.
Fired right up.
Thanks for all your help guys!!!
Duba is offline
ShaneB26154
35
03-04-2021 04:05 AM
Urambo Tauro
09-07-2015 12:47 PM
KEM Motorworks
08-14-2015 10:13 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: Need help with mustang not starting
