275/40/17 or 275/60/15? Cant decide!
Looking at some new shoes for my 67 coupe. Id like to run some Mickey Thompson ET Streets. I cant decide between a 17 inch rim or a 15. If it was 17...i would go 17x9 (5.5 BS) Torque Thrust II with a 275/40/17 Mickey. If it was a 15 I would go with a 15x8 (4.5 BS) Cragar s/s with a 275/60/15 Mickey.
1) Will I have any fitting issues with any of these sizes? Stock ride hight in the back. Brand new 4.5 Leafs, and I have the chrome fender molding on my car also. Fenders are not rolled.
2) Will 17s result in less traction than the 15s due to less sidewall? I remember hearing that due to a smaller sidewaller, the tire is stiffer and has less flex, resulting in less traction. Whereas the 15s has a fat sidewall that can flex nicely.
I need to lay down a big paw print bc a 408 stroker will be going in! Any suggestions, pictures, comments are appreciated.
Thanks!
Thanks!
To me, nice not only involves comfort but handline ability.. I know that in a classic this isn't exactly sought after as it's not built for handling, but a smaller wheel larger sidewall will handle a bit worse in turns because of the flex.. This is my main reason why I don't drive around with 15x10s on the street.. If handling isn't an issue to you then go for it..
Thanks!
Thanks!
I can also state I run a 275 40 17 street tire on my 351w powered 68.....and I do like the look.
oh that makes sense...i can see how the 17s will handle better...but then in a straight line ill just be lighting up the tires bc it wont grip...or is there really not THAT much of a difference between the sidewall of a 275/40/17 and a 275/60/15
dodgestang...im expecting at least 500 hp from this 408w...the rear suspension is 4.5 leafs, calvert drag shocks and cal-tracks...even though this is going to be a street car haha...a 5 speed will be going into it as well...i guess being realistic i can expect low low 11s out of the motor...i saw on your chart that a 17x9 with 5.5 bs on a 275/40/17 will fit even with the chrome fender molding and no rolling so that got me pretty excited...thats a big wheel haha. The low sidewall doesnt hurt you on the street?
