will these work?
Old 10-04-2012, 07:55 PM
TomKat
TomKat's Avatar
Default will these work?
i have 65 coupe 289 holly 4 barrel torker intake shelby tri-y headers, gt.350 side exhaust backed up behind c4 trans.
will these lifters and cam work with my current set up. it runs like a charm now i just want to make it same spec wise as gt.350
http://www.cobranda.com/289fordhipocam.html
http://www.cobranda.com/289hisoli.html
let me know if these would be good choice or if there is better out there please inform me thank you mf!
TomKat is offline
Old 10-04-2012, 09:23 PM
guitarman376
guitarman376's Avatar
Are you making a clone? If you aren't stuck with having it be identical there may be a bette r performing cam for your setup if you do your homework. However if you are set on having it be the same then go for it.
guitarman376 is offline
Old 10-04-2012, 10:24 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i cant remember the cam part number but there is a hydraulic cam that has the same specs as the hipo cam...if your heads arent setup for solid cams youll need to have them fixed to work with the solid cam...
rmodel65 is offline
Old 10-05-2012, 06:28 PM
TomKat
TomKat's Avatar
i think your right and i should possibly look into hydraulic cam then.. thank you for the input
TomKat is offline
1TUFF302
11-05-2015 04:02 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: will these work?
