Scott Drake LED with Ron Francis kit
Is anybody runnin Scott Drake sequential LEDs with the Ron Francis express kit? The kit calls to replace the flasher with the Drake module, I keep blowing a fuse and or heating the front signal lights when connected otherwise the rears work fine without the front hooked up. If anyone is running them how do you have the connections running to the fuse box? Thanks.
Do you have LED blinkers in the front? I have the LED sequential tail lights and for some reason I have to run regular bulb lights for my front signals. What you describe happens to me when I put in, cooler, lower energy using LED blinkers....I haven't cracked the code either. so I just run regular bulbs up front.
James
James
jwog666
12-27-2021 08:09 PM
