No heat but fan blows
Just like the title says my Old Air A/C/heater system blows but never warms the air. Besides checking fuses what else could be the culprit? The whole system is a year and a half old.
I just had the whole system flushed 2 months back so I dont think it is clogged. Engine temp last night didnt get above 165 so maybe the thermostat isnt opening all the way? I had the timing changed to keep it running a little cooler but now that the winter is here maybe I should set it back.
Hi,
If the above ideas don't solve, go to a 180 T/S. The way I view this, that 165 is going to open sooner and will allow the coolant to circulate sooner thus not absorbing as much engine heat as a 180. A 165 is better in the summer as you need to get a jump on the heat potential.
Good Luck!
Good Luck!
