Oil pump intermediate shaft
Old 12-11-2012, 08:11 PM
69Volunteer
69Volunteer's Avatar
well I may need to pull the pan regardless. I may have it reversed in that the ring is on the oil pan side. I can pull the shaft up out of the dizzy hole until about 3/4 of the way up and it catches that ring and wont go any further. Makes more sense to have it reversed.
It still seems like the shaft will pull out of the pump when I go to prime the motor and remove the primer.
69Volunteer is offline
Old 12-16-2012, 09:22 AM
69Volunteer
I'm posting this in case anyone has this issue in the future. The shaft actually has a top and bottom. The bottom that fits into the pump is squared off while the top that fits into the distrib is tapered. The ring is at the top and I found that I had to insert the shaft into the pump and slide it into the distrib hole before boltng it to the block. You will see that if you pull the shaft from the top, it will slide up slightly but not enough to come out of the pump.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
9550
10-26-2015 05:01 PM
b8checker
09-30-2015 07:11 AM
dudeguy421
09-24-2015 11:16 AM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: Oil pump intermediate shaft
