C4 Tranny Question
C4 Tranny Question
I'm Brand new to this forum and want to thank y'all for all the great info I've gathered from it over time. I figured its time to join in. Here's my latest issue. I have developed a tranny fluid leak at the Passing gear kick down. Is the fix as simple as removing and replacing gaskets. Tranny is a C4 Cruise-o-matic.
Thanks again,
Thanks again,
Thanks again,
Thanks again,
Here is some good information to know about the C4 transmission...http://realperformancemustangs.com/g...transmissions/
Could be the Kickdown O-Ring or the Shift Linkage seal behind the kick down lever. Most Tranny shops will just give them to you if you ask. Or charge a small amount. They usually have plenty lying around. Nothing over 5.00 bucks for both I would say.
treesloth
09-28-2015 07:03 AM
