electric fuel pump?
Old 08-17-2014, 02:24 PM
67mustang302
67mustang302's Avatar
Use a return style regulator, otherwise you need a PWM controller. Fuel shouldn't get too hot.
67mustang302 is offline
Old 08-17-2014, 02:57 PM
Starfury
Starfury's Avatar
I'd recommend against wrapping ceramic coated headers. I've heard that wrapping them will ruin the coating.
You can tee from the current oil sending unit. You'd just need a switch that's normally open but closes with some minimum pressure, then tie that into the fuel pump relay wiring along with a bypass for startup.
Starfury is offline
Old 08-18-2014, 01:55 AM
barnett468
barnett468's Avatar
Originally Posted by MonsterBilly
If I use a oil pressure switch, should I just use a tee where my current oil sending unit is?
Also, I'm in AZ and it's dam hot. My car when I'm in traffic gets really hot. I already have 3 electric fans, one pushing and two pulling. With a really big radiator. I do have ceramic coated headers but will wrapping them help reduce the heat in the engine compartment
hello;
the header wrap will help but will not ;likely be a big help.
you need a bigger radiator and'or fans.
yor rad and fans are likely chinese and if so, they are junk.
if you have money and want to fix it i can tell you the best and cheapeat way to fix it but i need very specific details forst. just ;let me know.
FYI - The biggest baddest fan on the planet is a lincoln mk VIII. it will sick small animals and children right off the street as you drive buy.
http://fanconversion.com/Product_list.php
around 4500 real cfm at around 42 amps.
it can be trimmed to be thinned and just a circle. the next best one is a ford contour two 12" fans.
from a mercury 4000 cfm.
barnett468 is offline
Old 08-19-2014, 01:30 AM
MonsterBilly
MonsterBilly's Avatar
Money is not an issue at this point. That Lincoln fan seems nice but I only have 3.5 in. Of clearance.
My fans move a ****load of air. Please take note that I sit in traffic during daily temps of 115* is hot as hell. I do have a/c and the condenser is in front of my radiator.
I was thinking about trimming out the license plate area of the front valance and rolling the edge so it looks good. This may let more cooler air in.
I also have a stock water pump on it. I was thinking about a high flow pump to help.
my current radiator is a 24inx18in becool 3 core aluminum
When I had my last built 289 with the same set up it ran cold as ice. The only diff. Was the water pump.
MonsterBilly is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
b8checker
10-08-2015 12:55 PM
Sixx
10-05-2015 07:36 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: electric fuel pump?
