Suspension ideas for my 1973 Fastback
Old 01-07-2013, 11:09 AM
Iconic.Motive
Iconic.Motive's Avatar
Originally Posted by andrewmp6
Our suspension bible http://home.bresnan.net/~dazed/suspension101 just ignore the lowering the upper a arm part in 71 ford lowered the upper a arm on the mustang.The front you can go for oem with upgrades to full coilovers the rear is harder no one makes a 3 or 4 link for it yet.I heard a guy on another forum took a 3 link for a 70 and made it fit but no pictures to prove it.For normal parts for it http://www.ohiomustang.com/ anything billet http://www.eddiemotorsports.com/ Anything parts you need help finding or ideas let me know.
Wow, this is great. I'm glad to have someone that can help me out! I will be keeping in touch with you for parts and whatnot.
Thanks!
Originally Posted by boogerschnot
Looks like some fun!
Ha, can't wait to get started on it! It's still in the shop getting the transmission and engine checked out.
Iconic.Motive is offline
Old 01-07-2013, 11:36 AM
TommyK
TommyK's Avatar
Street or Track makes some nice stuff.
http://www.streetortrack.com/
A friend of mine installed their front coil over set up. I haven't ridden in it because its in the middle of a restoration but it sure looks nice.
TommyK is offline
Old 01-07-2013, 11:48 AM
1971mach1
1971mach1's Avatar
There's an active forum for 71-73 mustangs at:
7173mustangs dot com
Not sure how extensive $$$ you want to get with suspension.
Lots of companies make coil-over for 71-73 model years but there are very few options for rack and pinion. RRS in Australia and Fatmanfab in USA are the only ones I know of. Fatmanfab is a complete custom front suspension kit with an Escort rack. If you're rebuilding everything anyway it may be the way to go.
RRS has a new R&P kit but I haven't heard much about it other than they're a little difficult to work with being in Australia.
The stock 71-73 Mach1 suspension is decent if you replace the loose/worn components. Rebuilding the stock steering box really tightened it up too. That's the route I went and it rides good. It handles "old school" but very good old school. It stays flat in smooth corners but steering is still more vague than R&P (but I didn't buy this car to handle like a new car anyway and definatly not road racing).
The Mach1 suspension (aka competition suspension) has front+rear sway bars and heavy duty shocks+springs. If you have the standard suspension, I'm sure you can add these components.
Or if your on a budget, just adding a front sway bar, good shocks and replacing/rebuilding the worn stock parts would help alot.
1971mach1 is offline
Old 01-09-2013, 01:37 AM
andrewmp6
andrewmp6's Avatar
I think the fatmanfab kit your talking about is the one you use the fox or newer struts and spindles right?I'm not a big fan of that kit or struts as far as handling goes.The factory stuff isn't bad but can be upgraded some to make it handle better past that you have coilover kits which are nice but pricey too.It really comes down to how you want the car to be.It can be a stockish with light upgrades or a pro touring monster your wallet is the only limit to a early mustang.A good general info site http://www.429mustangcougarinfo.50megs.com/ its for 71 429 cars but besides the engine and the front end sheet metal and few tiny things a 71 and 73 are almost twins.
andrewmp6 is offline
Old 01-09-2013, 03:55 PM
Iconic.Motive
This is good to know - they are pretty expensive but maybe for different projects. Thanks for the link man!
Interesting, I didn't know there was a forum just for those years - I'll have to check it out. I haven't heard much about the RRS and FatManFab but I will definitely check it out and see what they offer.
My mechanic says that I really don't need a kit - just needs a few parts to replace. Therefore I think I'm gonna stick with the 'old school' ride. That way I would understand the whole old school style back in the day when they were making these mustangs. I have a thread going on and will keep updating it every time something happens to the car! The link is in my signature.
Old 01-10-2013, 04:12 AM
andrewmp6
andrewmp6's Avatar
Thumb around on http://www.opentrackerracingproducts.com/products/ the roller spring perches are a must they smooth out the ride a lot.
Old 01-11-2013, 01:01 PM
Iconic.Motive
Interesting. I think I'm gonna go with the stock suspension set up so that it has an 'old school' ride style. However that is something I will keep in mind as far as coilover set up or pro touring suspension set up. My wallet is not very big so I have to be careful on how much money I'm spending and all.
What exactly does roller spring perches do besides they smooth out the ride? I ask because I never heard of it before.
Old 01-12-2013, 02:21 AM
andrewmp6
andrewmp6's Avatar
If the front you have a spring perch its on top the upper a arm it holds the lower part of the coil spring.When the suspension moves up and down the spring perch pivots to keep the spring in line.On the factory made ones the bushings in the spring perch flexes some and can drag a little bit both are bad for handling and a smooth ride.The roller ones have ball bearings in them so the spring perch can move more freely.
poke68
12-15-2015 06:25 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
GimpyHSHS
09-18-2015 12:27 PM
09-10-2015 08:39 PM
Quick Reply: Suspension ideas for my 1973 Fastback
