65 hipo heads
Old 01-14-2013, 05:01 PM
maprato
maprato's Avatar
Unhappy 65 hipo heads
I bought a 90 mustang and was told it had a 289 hipo motor in it from a 68. when I removed the valve covers it was stamped with a 65, so it appeares to be a 65. It also had slotted push rod holes, which would conferm it to be a early65. when I looked at the rocker arms there was no nut on the stud, but the studs appeare to be held in with roll pins. also had a 5 stamped on the outer edge of the heads. Is it just a 289 from a 65? or maybe proto type of some kind????
maprato is offline
Old 01-14-2013, 06:05 PM
clowe1965
clowe1965's Avatar
Pull a lifter out, it its a solid lifter then maybe. Hydraulic lifter, youve been scammed. Though i don't think hipo motors were made past 66.
clowe1965 is offline
Old 01-14-2013, 06:18 PM
Coupe
Coupe's Avatar
Where "289" is cast into the head between the valve springs, does it have one or two dots above the "289"? Two dots = Hipo/K code...
Coupe is offline
Old 01-14-2013, 09:41 PM
Starfury
Starfury's Avatar
Also, hipo valve spring seats are cupped at the bottom.
Starfury is offline
Old 01-15-2013, 01:32 AM
andrewmp6
andrewmp6's Avatar
The odds are its a normal 289 a lot of people say engines are things they ain't.
andrewmp6 is offline
Old 01-15-2013, 07:16 AM
Al Newman
Al Newman's Avatar
How the heck did anyone take the time to get a HiPo 289 into a 1990 car and get it emissions legal? Rocker studs secured with a roll pin would be pressed in, whereas the HiPo heads would have had screw-in studs. Not likely that the motor is HiPo. Everything about the setup seems wrong. Just sayin'
Best,
Al
Al Newman is offline
Old 02-18-2013, 03:11 PM
maprato
maprato's Avatar
thanks for the reply. there is only 1 dot c code
maprato is offline
Old 02-18-2013, 03:15 PM
maprato
maprato's Avatar
Best,
Al
thanks for the reply. dont have to have an emissions test done in MI. yeah it looks like a regular 289.
maprato is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: 65 hipo heads
