Horn not working
Old 03-07-2013, 10:35 PM
polus11
polus11's Avatar
Question Horn not working
i have a '66 mustang, At, inline 6, 200 cid and I was told to buy a new steering wheel because the horn isn't working. Could there be another solution for this problem?
polus11 is offline
Old 03-08-2013, 06:44 AM
sammm
sammm's Avatar
You probably want this section -
https://mustangforums.com/forum/clas...tangs-tech-16/
sammm is offline
Old 03-08-2013, 03:14 PM
jlg2002
jlg2002's Avatar
You need to do some troubleshooting to see if the horns really work. Go out to the engine compartment and quickly apply 12 v directly to each horn using a jumper wire to the battery. Each should sound briefly when activated. If they do then you need get a wiring diagram and look at the column circuits. If the horns don't sound, check to make sure they're grounded properly and if they are the horns are bad.
jlg2002 is offline
Old 03-10-2013, 04:15 PM
polus11
polus11's Avatar
Thanks for your input. I'm new here and didn't really give the whole story. I did troubleshoot the issue and the horns work, fuses are good too. I just thought there might be something else besides replacing the steering wheel that would fix the problem.
polus11 is offline
Old 03-10-2013, 09:18 PM
clowe1965
clowe1965's Avatar
If the problem is on the contact plate/followers then yes you may have to replace it as the contact plate is molded into the steering wheel. Least that was the problem with mine.
clowe1965 is offline
Old 03-10-2013, 09:42 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yep probably corroded brushes in the steering column causing the problem
rmodel65 is offline
1TUFF302
11-05-2015 04:02 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Horn not working
