headlight problems
Old 04-02-2013, 04:44 PM
Bucky renegade
Bucky renegade's Avatar
Default headlight problems
I have a 72 grande and for some reason when i have my headlights on for probably 20-30 minutes they will suddenly turn of for a little bit then come back on and then it keeps doing it and i have no idea why any suggestions?
Bucky renegade is offline
Old 04-03-2013, 02:45 PM
jlg2002
jlg2002's Avatar
The high low beam switch may have a loose plug or is going bad or it could be the main light switch.
jlg2002 is offline
Old 04-04-2013, 08:45 AM
Starfury
Starfury's Avatar
Check your headlight plugs for poor connections. Next, check the headlight switch itself. If you can find no problems, you may have a short, or you may need to replace the switch. I believe the switch has a built-in circuit breaker. An intermittent short would trip the breaker intermittently.
Starfury is offline
Old 04-04-2013, 08:51 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i asume you are running halogens?? probably just the switch i had to replace it on my 72
rmodel65 is offline
Old 04-04-2013, 02:34 PM
scootchu
scootchu's Avatar
My bet would be the switch. Had it happen twice, each of which was the switch.
scootchu is offline
StalkerGT
11-28-2015 03:09 PM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
ccdguy
09-19-2015 05:20 PM
Mobiusone stang
09-07-2015 08:46 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: headlight problems
