bumpsteer kit I got locally for my stang 67 68 69
this kits work great & just paid half the price
Item Description:
Mustang 1967-69 Bump Steer Corrector Kit.
Bump steer is caused by the tie rod ends moving up and
down as the suspension travels. When Mustangs are
lowered, the tie rod ends get closer to a level position
and under braking can actually go past the level position
which causes the tires to toe outwards. This causes the
car to pull from side to side during braking. Bump steer
is corrected by relocating the outer tie rod downward
with an intermediate spacer block that mounts on the
spindle steering arm. This is a bolt on kit which
requires no welding, heating, or bending of any kind.
It will also quicken your steering ratio for better
handling and road feel!
unscrew the spindle from the arm
tight the block to grind the arm screw
secure it
grind it
fully flat surface
uninstall it and put the spindle screw
tight it
secure pin installed
drill spindle hole
install block security holders
fully tight the spindle screw
fully tight the security holders
if you want to be extra carefull I use on mine red locktight
[/QUOTE]
Item Description:
secure it
grind it
fully flat surface
tight it
drill spindle hole
[/QUOTE]
jwog666
12-27-2021 08:09 PM
09-16-2015 07:53 PM
