installing a 1 inch spacer ended up fixing a vaccum leak on my air intake
just passing this experience I had
I was installing a 1 inch fomoco spacer
when I change the carb studs on the air intake I found oil and gasoline inside the threads I read that you could have leaks thru there but not that big
I put teflon tape on the new longer studs that I made
when I checked the vaccum tester the needle was steady at 21
I really recommend all of you guys to check and seal those studs IMO
In my case it gave me a sweet idle on my 302
mryeah256
08-28-2015 02:01 PM
Figure8allday
08-22-2015 11:11 AM
