rough idle in gear
rough idle in gear
1967 289 Was running fine .. now idles fine until put into gear then extremely rough idle and stalls. Has good spark at all cylinders however 3,4 and 8 show no drop in idle when plug wire is removed. My initial thought is timing chain. As a side note the trans(auto) started acting up at the same time, not shifting into 3rd gear.
OHM all of the wires. Check the cap for tracking. Still running points? Check the Dwell? Check the modulator rubber hose for signs of wear, cracking etc. You could have a vac leak. In fact, check the engine idle vac, while at it. I wouldn't think timing chain at this time.
Good Luck.
Hi,
Good Luck.
Good Luck.
Could it be something as simple as the idle dropping off when placed in gear? If so, is the malady you mentioned concerning your C4 causing the drop due to unknown drag in the transmission?
You mentioned no change in engine cadence when you pulled those plug wires (assuming one at a time). As you know, that's a sure indication of dead cyl., that is, if the wire was completely removed from the plug? There should have been a change.
Best,
Al
jwog666
12-27-2021 08:09 PM
musnicki
09-23-2015 07:11 AM
