1966 speaker grille does not fit
I am trying to install the speaker grille, and it does not fit the opening in the reproduction dash pad the PO installed. The opening is about 1/4 inch shorter side-to-side than the grille.
Am I correct in assuming it is just due to a poor quality replacement dash pad?
Thanks,
Bob O'Hara
Thanks,
Bob O'Hara
Been having similar problem getting a new dash pad to fit on my '65 (dash pad is for a '66). In my case, the pad just won't slip far enough onto the steel dash for the screw holes to line up along the bottom. AND....my speaker grill screw holes don't correspond to the ones in the dash...not even close. Like you, the pad was put on by PO, and I don't know the maker (but has a Ford logo embossed on the inside).
If you figure out how to fix yours...let me know...and I'll so the same from here! GOOD LUCK!!
Tom
Tom
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
